multi-band mobile antenna recommendations
w2edv
Northern NJ - FN20ux
Hi Everyone,
I just bought a 396XT and plan to use it in my car. I want to purchase a good multi-band antenna, and I'll mount it on the passenger-side of the rear hatch on my Subaru Forester. The driver-side of the hatch is the home of my vhf/uhf transceiver stick. I'll mount the scanner antenna using a Diamond K412SNMO mount because it is adjustable in 2 dimensions.
I've read about the Austin Spectra and it looks appealing, but I've read comments where some users consider it a bit fragile. I was hoping to use as much of the scanner's freq range (25-1300) as possible.
Does anyone have any comments about the Spectra, good or bad, and can anyone offer other antenna recommendations?
I've looked at this so much I'm getting myself confused - TMI, I think.
thanks in advance/73
w2edv
:confused:
w2edv
more info on mobile antenna recommendations
Hi Everyone,
I forgot to mention, in my original post, just above, that I also checked out the Diamond D-220, mini discone, on the Universal Radio site.
I was concerned that the counterpoises would hit the hatch - that there would not be enough physical spacing. This antenna had received remarks of it's fragility as well.
73
w2edv
nosoup4u
High Bridge, NJ
I used to own a Austin Spectra and didn't care for it. If you plan on monitoring the NJSP, then stay away from that one. I use an Antenex ABSCANC and that works pretty well all around.
w2edv
thanks, John.
Everyone - thanks for your input - I bought a Larsen tri-band from cheapham.net; the Diamond hatch NMO mount is coming from Universal. If I'm lucky, I hope to get the stuff by Friday so I can install it over the weekend.
73 - I appreciate the input from everyone.
w2edv
Earl
tglendye
Blue Ridge Mountains, Shenandoah River
Hi Earl,
I came across this thread while searching for info on the Spectra. Just wondering how you liked your Larsen. I will look at that one, as well.
Thanks,
Todd
thewenk
Idaho DB Admin
Eastern Idaho
