Multi-Mode and Multi-Band Portables
human8472
What are the various multi band and multi mode portable radios that are actually in existence and not vaporware?
I know of the Tait tp9900 which covers VHF, UHF, and 700/800/900 MHz and supports both Analog, P25 and DMR. What other portables are out there for Kenwood, Harris, Motorola, and others?
Kenwood/EFJohnson VP8000: VHF, UHF, 700/800MHz, Analog, P25, DMR (and supposed to eventually add NXDN).
Multimode if you count Analog:
Harris XL-200P: VHF, UHF, 700/800/900MHz, WiFi and LTE. Analog and P25
Tait TP9800: VHF, UHF, 700/800MHz, Analog and P25
Bendix King BKR9000: VHF, UHF, 700/800MHz, Analog and P25
Motorola APX-8000: VHF, UHF, 700/800MHz, Analog, P25, WiFi
Motorola APX-Next: VHF, UHF, 700/800MHz, Analog, P25, WiFi, LTE
There is some older stuff, like the Thales Liberty, but that's almost 20 years ago.
Not going to mention the Military stuff.
Or the Chinese toys.
AM909
Radio/computer geek
SoCal
If you take out the Multimode part the Kenwood NX-5000 Series Analog NXDN DMR and P25 in Conventional and Trunking configurations.
The NX-5x00 are not multi-band, though they are multi-mode, as are many others.
AM909
Radio/computer geek
SoCal
Do any include low-band or 900 MHz?
Right the Harris XL-200P does 900MHz.
No low band on the portable, but the XL-200M mobile does, or at least did.
For low band multimode portables, the only one I'm aware of is from TPL Systemes out of France. Not sure if the portable has FCC Part 90 certification, but some of their radios do.
TDH3G
It has a variation of DMR in it. It adds a 3 "time slot" for low speed data, similar to an old ISDN 2B+D type thing. Not sure if it can be made compatible with regular DMR.
Echo4Thirty
Colorado Springs, CO
TDH3G
Just as a point of clairification, the XL200P does not have the hardware to do 900MHz even if it has the option installed it in (same for Low Band), there is a variant of the XL185P that is single band 900 MHz only.
The XL200M does have the low band hardware and IIRC also 900 MHz. Neither will go out to 927 unfortunately.
human8472
What advantage does LTE provide for the Harris XL-200P? Is it just the ability to make a cellular call? Is it VOIP?
merlin
DN32su
XG-100M does low band. for TX though, you need the HPA, also on a separate antenna, The other 3 bands are the common VHF, UHF, 700/800.
(Maybe the same for the XL-200M) US $4,500.00 on ebay.
Harris BeON will allow the radio to connect back to the P25 core via LTE or WiFi. That's useful if outside the coverage area of the radio system, or inside a building where the radio system will not reach.
It will -NOT- do cellular phone calls. It can act as a (very expensive) WiFi hotspot.
12dbsinad
In another 5-8 years this will be perfected. Right now as it stands, there is about an 8 second lag time of no communications when it switches back and forth. It will solve A LOT of problems, just not perfect yet.
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Interesting. SmartConnect is pretty much instant from LMR to cellular and a couple of seconds the other way around. Or at least that was my experience.
Yeah, Harris has some catching up to do. Been running their stuff for a few years now and I've found the issues.
