I'm looking to build a multiband ground plane vertical or j-pole antenna. I'm looking at a tri-bander with the center frequencies of 154, 507, and 867. I've been able to find the design specifications for the verticals, ground planes and J-pole, but I'm having trouble understanding the "trap" portions of the antennas. First, I'm not sure if I'm labeling this coil between the vertical elements correctly. I can't tell if it is a trap, loading coil, phasing coil or what. I'm trying to figure out how to design the "traps" based on my frequencies. I own and have searched through the ARRL antenna book (20th) and have been up and down the web. With the ARRL book, I'm trying to understand the design as it relates to the VHF/UHF frequencies. I can't seem to convert the trap information for multiband 40, 80 meter bands, etc. to the higher frequencies (coil diameter, number of turns, wire diameter, etc.) The reason that I'm doing this is because I am limited to an attic mounted antenna with a height of less than 6 feet. I hope that I've explained this correctly. Any help would be appreciated. Also, any alternatives would also be welcomed.
Thanks much,
Rich
Thanks much,
Rich
