Multiple band antenna
jaspence
Michigan
If you use a longer antenna such as those recommended, be careful when it is extended. Moving quickly from the normal vertical position can put edxtra stress on the connector and break the solder joint over time.
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
Also make sure you collapse or remove it entirely if you place the radio on a table. If the radio gets knocked over or dropped, this could spell disaster for the connector and/or antenna if it lands the wrong way
