Multiple control channels
Plutonium94
Argentina
I have a Motorola XTS 5000 800mhz 9600 baud trunking. I'm currently monitoring a trunking system of my city, but I have some problems. The system has 4 control channels and some of them only monitor specific talkgroups. So the radio only scans one control channel and I can't listen all the talkgroups or failing to change the control channel that the radio scans. Is there any solution to this? Can the radio monitor all the control channels simultaneously? Thank you.
IAmSixNine
Dallas, TX
Is your system set up with layers.
RFSS 1 Site 1
RFSS 1 Site 2
RFSS 2 Site 1
something like that?
If so what you need to do is treat each one like its own system and then program the associated talkgroups that correspond to that particular site.
I monitor a system like this and its worked great.
Plutonium94
Argentina
I have the radio programmed in this way: 4 trunking systems, all of them with the same sys id but a single control channel on each; 4 trunking personalities with the talkgroups (they are 28 in all the system) corresponding with each trunking system (control channel); and then the zones channel assingment and the scan lists. I also have 28 conventional personalities of course. Is there anything wrong? The radio keeps monitoring the same control channel although I select a zone that have talkgroups programmed with other of the 3 systems. So I can only listen the talkgroups that that control channel monitor. Thank you for your help.
duffy109
Greater Cleveland Ohio
RFSS 1 Site 1
RFSS 1 Site 2
RFSS 2 Site 1
Perfect reply. I have 4 trunk systems in one XTS5000 and one zone has talkgroups from each so I can scan easier.
