I now have 3 Scanners in my RV I want to use the existing FM antenna on the roof )eventually replace it with a better one) the factory installed antenna in my Rig is a simple FM antenna basically a Automotive type it has the typical plug that goes into the AM/FM CD player installed into the cabinet in the kitchen! The plug is a Automotive type that most car radios use (I forget the technical name for it) is there. Simple way to split off this plug efficiently without loosing to much signal strength? Will I need some kind of amplifier? I basically want to split it at least 2 ways ideal 3 ways from the Car radio style antenna plug to the BNC used on the radios. I don’t want to cut anything in the rv so I can restore everything when I sell it! I don’t know how many RV Owners are here they are a real pain to wire if something gets damaged! See photo of plug I have the circled yellow part
