MURS Operations
johnls7424
Somewhere in NJ
Simple question: Can you operate a MURS frequency with a tone code to limit the amount of traffic/interference on it?
johnls7424
Somewhere in NJ
Thank you. I just wanted to know cause nowhere that I could find online stated anything about " tone-codes" and if they are allowed or not
RandyKnowles
Chicago North Shore
Just remember that tone coded squelch does not eliminate other traffic or interference. It just masks your receiver from hearing it. The other traffic or interference is still there, which can lead to frustration. Also, carrier squelch monitoring is mandatory before transmitting to make sure you will not interfere with other existing on going conversations on the frequency…..
kc4jgc
Virginia Beach, VA
Yeah I am not worried about that. Simply put I can encrypt if need be.
That's NOT encryption. You're just telling your ht to send a specific CTCSS and not open the squelch unless that same CTCSS is received. Your transmissions are still in the clear.
kc4jgc
Virginia Beach, VA
Wirelessly posted (BlackBerry8320/4.5.0.81 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/100)
OK; your last post wasn't clear on that. Still whether in the clear or not, you need to ensure the freq is clear before transmitting.
tj20
In part 95...
Coded Squelch: LEGAL
Scramblers: NOT LEGAL
Digital Encryption: NOT LEGAL
Using any radio in MURS that has scramblers or encryption: PROBABLY NOT LEGAL (because it won't be certified)
Then I guess my Motorola rdm2080's (murs only radios) are illegal because they have voice inversion :)
johnls7424
Somewhere in NJ
Lets be honest. MURS is license free. Most people don't use it in rural areas anyway. Also most businesses either have a FCC license and granted Frequency or they use something else like iDen or Direct Talk style radios. MotoTrbo radios too have been increasingly popular because of range and the easy switchover to digital. So if the radio does have voice inversion or some other form, strictly MURS or not I wouldn't worry about it. As long as you don't cut off someone else talking on a MURS frequency you should be fine. Also operating on 2 watts is a must/requirement.
rapidcharger
The land of broken calculators.
Yes it is a murs only radio made by motorola. And before anybody says it yes I know voice inversion is not secure. RDM2080D Motorola Two-Way Radio, Handheld, MURS VHF, 2 Watt, 8 Channel, PC & Field Programmable,
That's not what I asked. I asked if it was a MURS certified device.
Here's a hint. If it is, it needs to say so on the unit itself. If you have one, look for a label that indicates that it is a MURS certified device.
Lets be honest. MURS is license free. )))
Let's be honest.
MURS is LICENSE BY RULE.
Not license free.
(((Most people don't use it in rural areas anyway. Also most businesses either have a FCC license and granted Frequency or they use something else like iDen or Direct Talk style radios.)))
This is not a statement that is based on fact. And iDen... I hate to break the news to you about iDen but.....
(((MotoTrbo radios too have been increasingly popular because of range and the easy switchover to digital. So if the radio does have voice inversion or some other form, strictly MURS or not I wouldn't worry about it. As long as you don't cut off someone else talking on a MURS frequency you should be fine. Also operating on 2 watts is a must/requirement.
Why is ok to pick and choose which rules you want to abide by? Going over 2 watts is not OK but encryption is? That's like saying it's ok to drive drunk as long as you don't speed. But whatever helps you sleep at night.
There is a reason the rules are what they are.
i run p25 with adp all the time
And there's a reason this forum has the reputation that it does. :roll:
