Quote"
Next time you have that programmer plugged in type QUALITY in the field for running the applications and tell me what it does!
I will have to dig it out again my wife told me to get it off the dinning room table, along with the dozen or so radios. What other Easter Eggs are there? I was wondering the same thing about some other EEprom fitted to the location where the old die was that maybe can be programmed with a laptop instead of the R1800. Something I should look into too thanks for the idea.
I have one similar from DEA but it is totally blown out, DES, Scan and 64 channels in subdue face, with the ABCD switch and 3 position PL/ secure/ scan switch. I can just imagine what it cost us taxpayers for that radio ( speaking of costs I found old documentation for the MX-R for Navy Seals and those radios ran about 4K each in the 80's). I know you have to specify the numer of channels when you power up the later version programmer using C and D proms to get the 16 channels. the A,B version doesn't give you that option. That bi-level switch sound familiar to what is used in the RR Spectra, getting 99 channels out of 4 control lines.
