My Bed Side Shack
Windsor, ON CANADA
#1
In the pics are my BCT8 my pro-2020 jest to monitor my local police dispatch and the BCT8 is for every thing else. in the other the chrome box is a 24DB Delhi amp for the bct8 and the other two pics are my upstairs antenna a 3el beam i built. the 2020 jest was a small window antenna because the local police is only a half mile away from my house and so is the fire dept. The last two pics are of my other stuff witch is all ready posted under VE3FND's Shack.
Fortunately, GA
#5
Guessing that you are single:) Nice set up though! I'm lucky to have a SW on my nightstand and a hand held scanner for when the sirens wake us up.
Larry
