My Experience With RTL SDR V3
ronenp
Unfortenetly most iof the SDR's ( not only the rtl-sdr-v3) suffer from very low immunity to strong signals
as sonn as you connect them to outside antenna they receive all the spectrum with a lot of intermodulation
of course uou can download the RF gain but then you will get poor sensitivity so be happy that it is not only the RTL-SDR that behave like that but akso more expensive radios the air spy os not much better although it have 12 bit ADC the big advantage i see on it is the wide span
Dirk_SDR
Germany
With "the air spy" you probably mean the Airspy R2 with a max. bandwidth of 9 MHz.
The Airspy HF+ Discovery mentioned in this thread has a max. bandwidth of about 0.9 MHz.
Both have quite good RF filtering, so they overall do much better than cheaper RTL-SDR sticks.
The Airspy HF+ Discovery is a strong performer at frequencies below 35 MHZ, but if you are interested in frequencies above 80MHZ the SDRplay RSPA1 is more sensitive has a larger bandwidth and covers more frequencies and is less expensive.
Airspy HF+ vs. SDRplay RSPduo at MURS Frequencies.
