My HT1250 Needs New Volume-Pot
Vaughn
I have an HT1250 that will be fine one minute and all of a sudden go to FULL BLAST!!!! I'm assuming the volume pot needs replacement. Anyone on here have experience with replacing those? I'm seeking a repairer lol. How much $$$ am I looking at?
nosoup4u
High Bridge, NJ
Try opening it up and give the pot a blast of wd40. That fixed one of my MT1000's a while back.
Tech792
Central NJ
Volume control failure in the HT1250 is a common problem. They eventually break and spin completely around where you can't turn the radio off. I've changed about a dozen so far in my fleet of about 90+ radios. They're not that hard to change out. John made a good suggestion above although the switch itself is sealed and it may be hard to get any spray into it.
Vaughn
So that will probably fix the intermittent audio? Should I just give it a quick shot or maybe try with a q-tip or something? I don't want to get it all over the radio lol
Vaughn
Well, it's still doing it. The volume has a mind of it's own. It will be at a steady, comfortable level and ALL OF A SUDDEN IT'S LIKE THIS!!!!!!!!!! LOL
Tech792
Central NJ
I don't recommend shooting WD40 into any radio. It might start eating the board. Use tuner or switch cleaner spray.
n2hbx
Lady Lake, FL
Look at the solder connections of the volume pot under a magnifier...might have cracked connections. A quick check would be to just go ahead and resolder them and try it.
Larry
K4APR
Chesapeake, VA.
Yeah, I have to agree. After working on Moto portables for five years, I saw many that came from the factory with bad solder jobs. Somtimes all it takes is to wick the old solder and reflow some new on to the connections.
