My Humble Shack
NoRide
New York
Hello RR members. :)
Thought I'd post a couple pics of my humble shack. Only started about 3 months ago. With the help of members, I feel I have some good equipment and a solid starting point. Use the Pro-97 mainly for trunking and the BCT-15 for everything else. Not much to look at but here it is. :eek:
Moved the Scatenna and RS 20-176 back inside for now as I never came up with a permanent mounting solution. It's in a unused spare room. Looking for something to act as a base for the pole so I can get my bar stool back. :lol:
NoRide
New York
Added more to the family... Another Pro-97 with a Diamond RH77CA antenna and a Bearcat ESP-20 ext. speaker. :D
Imagine sleeping with all that RF activity beside your head ..... DrainBammage?
Very nice set-up, Quiet low profile look yet effective. Good Job!
jonny290
Denver, CO
Pshh, he's not even transmitting.
I've got a 50 watt 2 meter packet node that ticks all day long, antenna is about 10 feet and one exterior wall away from my head whilst I sleep. No brain damage yet...but then again, I do try to debate on QRZ sometimes, so even that might be suspect.
NoRide
New York
Update. :cool: My newest toy. Wilson 301111 800 Mhz Yagi.
The "control center"minus 1 Pro-97 which I keep at work.
NoRide
New York
The yagi itself is nice. Good build. As for performance, I only picked up about 1 bar (at best) compared to a window mounted RS800. But, I live in a remote country area with ridges and such. Typical of the Catskill area. So, I really didn't expect much. Pulls similar to the RS800 (one should never underestimate this little guy) but does have a cleaner signal.
In the video provided, you can see the BCT15 that I use for trunking hitting two different towers. The "Ulster Co." tower is about 16 miles away from what I understand and the "Dutchess Co." tower is somewhere in the range of 33 miles away though I don't know the exact location. Hey, I'm new at this! :p In the spring, I'll experiment with it outside and see if it will be worth my troubles to mount it on a mast.
Video [wmv - 4.76MB - 1.65min]
mancow
N.E. Kansas
No matter where you live it will be worth your time. You can't beat an exterior antenna.
StevieD
Farmington,MN
Love the set nice and clean,Plus like the video to.I see what you mean about only one bar for signal but still nice and clean audio
