My Motorola Gp-68 Error .04?????????
cody1092
I got this radio online and it was working fine until I was responding to a fire and i went to call in and it gave me a "Error .4". I paid like $150 for it with shipping from china and I call Motorola and they said that the FCC did not approve it, so they wouldn't give me help because it was from china or what ever. I really Can not spend more money and would like to fix it...........please help.......pm me or reply...ASAP
P.S I tried to reset and it wouldn't let me it just gives me error tones......
fwradio
Texas DB Admin
Fort Worth, Texas
Haven't seen that one personally, but the big M (as much as I hate those crooks) is right in this case. There were a few when they first came out that did have FCC ID printed on the label. I actually have one that is legal. Otherwise, they are not legal to transmit with. There is no way to make them legal either. There are way too many firemen in the country trying to save a few dollars buying import models of Motorola and Kenwood radios that are not legal to use in the US and have no support if there is an issue.
It is usually cheaper to go ahead and spend the money to buy a legal model. There are also plenty of radios available that do a lot more than the GP68. It is a very basic radio as far as what it can do and the number of memory channels.
zz0468
175 DME, HEC 358° Radial
I have a GP68, have had it for years. I've never seen any error codes, the manual doesn't mention any error codes, and a Google search didn't turn up anything of use in referencve to error codes. Don't know what to tell you other than the fact that, in comparison to other radios out there, it ain't all that and a bag of chips. Yay. It's keyboard programmable out of the ham band. =|
Mine has spent the last 3 years sitting in a box because there are far better options.
chrismol1
Saratoga
I have a couple dealer programming papers on this radio
For the GP-68 here is the error code scheme:
Err.01
Incompatible software.
Can't clone these two.
Err.02
Timeout error.
Check cable connection. Verify slave is on.
Err.03
Master checksum error.
Master needs to be serviced by dealer to enable cloning.
Err.04
No Programmed Channels.
If the slave, try again. If master - or slave still won't work - see dealer.
TO reset:
* turn off radio
* press & hold the button marked "mem"
* while you press & hold the button "mem", turn on radio
* now, you are in "spm mode"
* press the PTT, & hold
* While you press & hold the PTT, enter the #s 1, 3, 5, 7, 9
* At this point, the radio displays the message "erase?".
* while you press & hold the PTT the radio will display the message "erase?"
* you press the yellow button (Light)
* Your radio is now reset
cody1092
Err.01
Err.02
Timeout error.
Err.03
Err.04
TO reset:
* turn off radio
**Yea i cant even reset it at all.......the guy wont let me return it....any thing else i can do....
chrismol1
Saratoga
Put it into dealer progrogramming mode:
While holding depressed the PTT, Monitor & Enter Buttons turn on the radio to lock the keypad. This will protect all of your critical programmed parameters from being tampered with. To bring the radio back to the program mode, Turn off the radio. Hold pressed the PTT, Monitor & Scan Buttons & turn the radio on.
The try reseting it again
