I love it. But as usuall the software has some minor bugs. I've noticed the software program for the Grecom is the exacct same software maker for radio shacks Pro 106 that I own and the funny part is I have to be carefull not to confuse the programs. One day I opened up the Radio Shack user interface with the Grecom 800 ez plugged in and renamed the boot, changed some freg's, updated library then I noticed there where allot of extra things missing. THIS IS THE ANOLOG VERSON! But it actually worked and updated my card and talked to scanner.
Anyways. I love this scanner although I have had some problems with software on this one in the medium range. Thiis micro sd card seems to get errors on it very easy, this seems to come from to much update checks or especcillay after optimizing the card. The scanner will die,windows won't reconize it anymore with deive faliure. I unplug the scanner and turn it on for error messages.
Well instead of coming in here. I knew this was computer related and a simple software problem. I refused to give up on the Grecom 800ez.
If yours does this to you. Your best bet is to get a micro card reader that plugs into your computer as a periphial. Now format that micro card clean down to nothing. Put it back on your scanner. Your problem will be solved.
I no longer optimized or at least not to often. My issues alway like to happen after optimizing the micro card.
Also make sure you click on file, new configuration, highlight 0 and select yes. This will erase all your scanner set freq's scanner light settings, default anything you changed on the boot dispay, change your display back to simple mode instead of advanced like we all like it and so forth. IF YOU SET A PASSWORD THAT WILL REMAIN.
Last but not least if you get this stuck boot error message on your Grecom 800 EZ
General settings page then at the bottom click default all scanlist.
Your library will still be on your software all your firmware and other updates will remaine and or be on your hard drive your will need no new updates unless they release some while you do this process and anything is possible with all these freqenxcies being changed.
plug your Grecom800ez in then upload your library first
then remake your scan list (I like zip code verson allot but old scholl for some things)
Your done.
Oh pray for a software update, it's not your scanner. The problem is in the software, very buggy but I have found ways around most all of it.
Anyone else having this simular problem?
Otherwise I love this thing. I do recomend getting an after market antenna because that stock one is for the birds.
I typed this fast. I took typing in school. My hand type faster than my brain can get the singles to them so forgine the errors becuase i am not spell checking today, to lazy.
Get one of these antenna's makes your scanner look well should I say a bit more pimp (in steet lago) or professional (In professional terms)
Police Scanner Antenna Tuned 800 900 MHz Pro Digital Scanner Upgrade | eBay
Your done.
