My Shack 2019
737mech
Clark County, NV.
#1
Ok from left to right I have a laptop for dsd/acarsd/and winamp streaming then I have three DTR650's. Moving on I have on top a Regency Aircraft monitoradio/ A Pro-2051/ BCT-15/ BCD536hp. Next is a TYT MD-380 and a Wouxsun KG-UV9d. Under that is the Pro-2042. The desktop mount has BC125AT/PSR-310/Psr-500. Note they don't look that way because the PSR-500 is actually in the PSR-310 case and the PSR-310 is in the painted PSR-500 case. Next the BCT-15x/ PSR-410/ BCT-15x a SEC 1212 powering them as well as the next scanner the Pro-2035. Right side of that is extra monitor for ADSB exchange radar tracking and finally a Motorola XTS3000.
Fairport, ,New York
#2
Great set up! I’ll bet you can monitor all sorts of stuff. I too am an aviation enthusiast so I’m impressed that you have a dedicated air band receiver and you monitor adsb.
737mech
Clark County, NV.
#4
You have to admit there are some really cool aviation things in this area... Nellis Red Flag/ Area51 / Creech AFB Drones. Fun stuff!!
TailGator911
Fairborn, OH
#6
Very neat and clean! Makes me cringe and think of that spaghetti ball of wires and cables behind my shelves - *ack*
Sweet setup ;)
JD
kf4anc
737mech
Clark County, NV.
#12
Antenna farm is not very complex. All the scanners share a DPD Log Periodic, via EDA splitter drop amps and filtered with PAR Electronic FM Trap and VHF/SYM 162. The splitters are mounted under the bottom of the desk. The main feedline coax is Belden 9913. I also have up on the antenna mast an ADSB antenna, it has one of the flightaware 1090 filters and directly connects to the rtl/sdr v3 dongle. From there I bring it down to the office with a powered USB extension cable from Monoprice.com Works great! I have a rotator on the mast sometimes I turn it around looking for better signals in other directions.
