This non-scientific test was made inside my place checking for reception quality of commercial radio stations, FRS/GMRS, the NOAA weather channel and scanning various official channels. I've used the following for this test:
- Radio: Baofeng BF-F9 V2+ handheld dual-band radio.
- Antennas:
#1: Stock
#2: Nagoya NA-810 2.5-Inch Mini-Whip VHF/UHF
#3: Nagoya NA-771R 16-Inch Retractable/Telescopic
#4: Nagoya UT-308UV 22-Inch Magnetic Mount
#1: The stock antenna had difficulties receiving anything at all! I had to move around for getting ANY reception, and even then whatever came through was with strong noise.
#2: The mini (and VERY flexible) 2.5" Nagoya provided the same quality, so despite its tiny size, it's just as good (or bad) than the rather rigid and 2 X longer stock antenna. For small distances I can imaging using it when range is not a concern, because its flexibility and small size. I like it!
#3: The 771R, which is the retractable version of the "famous" 771, did better, but NOT much better than the stock and the small antennas. I expected stronger reception from this model. Maybe outside it would have been different, but inside, maybe 2 X better coverage, needed less movement for reception, but nothing I would call "great" about it.
#4: This 22" magnetic base one was the clear winner! No doubt about it! Inside just putting it on a glass table (even though it requires a metal surface to work) the difference was already obvious. Then, placing it on top of a metal shelf, the reception was significantly better compared to all of the others. MUCH better!
Then I put it outside the window on top of the air conditioner, which delivered absolute superior reception quality all over the board! Crystal clear on every channel! Fantastic reception quality!
Since I don't have a Ham license yet, I couldn't conduct transmission tests, but based upon these results, I would imagine the same, with the mobile magnetic Nagoya UT-308UV to be the winner hands down.
My only disappointment was the 771R. I expected a LOT MORE and a lot better from it. And YES, they are all original green bagged antennas, made in Taiwan, not some cheap Chinese knock-offs.
I attach a couple of pics, one is mine, the others are catalog images.
PS: I love being a newbie, I can discover all these things one step at a time.
- Antennas:
#1: Stock
