n00b ?s -> HARRIS P7270
Battle Born
#1
I just got a new radio and am getting ready to downgrade from RPM to Programmer. Following the guide from n0mb. I seem to have everything I need except the Radio Code DSP file to use.
Does anyone know where I can get a hold of the right file?
My radio is a HARRIS P7270 MAPT-T7HXX Portable
With the following features codes 01, 04, 05, 06, 07, 08, 09, 10, 12, 22, 23, 29, 33
And I did do a search of the net and this site before posting.
Thank you all for your time and help in advance.
GM
#2
If I recall correctly, the P7200 series radios are not supported by Programmer. You will need to use RPM on this model radio (P7200/P7230/P7250/P7270) to do any programming.
Battle Born
#3
Went back and reread the instructions again.... n0mb. net/?p=11 You are right, don't know how I missed that, even says it right at the top of the page. I was hoping I could because all I have access to is R18B02. Unless someone can PM me in the right direction ?
Thank you GM.
