N221UT - Aircraft type?
FLANO
AZ DB Administrator
SE of Tucson, AZ
#1
Hello all,
I am curious if anyone has an ID and/or photo of the aircraft with the N-registration of N221UT.
I have tried to identify this plane through all the normal means, FAA, Flightaware, FlightRadar24, with all telling me no information exists or that the number is not assigned.
But, I log this aircraft frequently via ADS-B and it is self identifying as N221UT, with tracking enabled.
It is usually found in the area SE of the Phoenix-Mesa Gateway airport.
Unfortunately, I don't get enough continuity on the flight patterns, due to the geography between me and KIWA.
Anyone have any information ?
Thanks in advance,
FLANO
AZ DB Administrator
SE of Tucson, AZ
#3
I was hoping that someone might take a photo of it, since it seems to frequent that area ... hint, hint, nudge, nudge :)
Because I can't seem to get an answer on it, so far, I have tentatively ID'd it as a US Government airplane, based on typical altitudes flown.
Just in case, someone happens to be at the right spot at the right time :O
#4
Hello all,
Thanks in advance,
If you're refering the callsign coming from the ADS-B message being N221UT, that callsign is entered by the pilot. It is not required to enter anything, nor is it required they enter the correct callsign. Sometimes pilots will enter 'stupid' stuff into the callsign field. I've actually seen callsigns such as "EATMEAT" or other sayings that will fit.
FLANO
AZ DB Administrator
SE of Tucson, AZ
#6
I am very aware of how it is entered and some of the insane things I've seen. But, I'm still seeing this way too often. I'll keep looking.
Thanks,
#7
Hello all,
Thanks in advance,
What's the HEX code?
EricCottrell
Boston, Ma
#8
Hello,
This is likely the code:
N221UT
Hex: A1E68C
Octal: 50363214
Binary: 101000011110011010001100
The ICAO 24 bit identifier in the transponder might be misconfigured. It is not an unknown problem with aircraft.
73 Eric
#9
Yeah I've seen several codes mismatched. Just make sure that the hex matches the aircraft.
FLANO
AZ DB Administrator
SE of Tucson, AZ
#10
Hello,
N221UT
Hex: A1E68C
Octal: 50363214
73 Eric
Eric,
It wasn't that Hex, but it came up as I was running out the door. It was A1BF0D. In addition to my setup, two others on PlanePlotter were also identifying it with the same N-Registration. Someone has indentified it as an "S211".
So, there ya have it...
EricCottrell
Boston, Ma
#11
Hello,
This is interesting as www.airframes.org has that ICAO24 as a SIAI Marchetti S-211 with the N211UT registration. Owned or operated by Aviation Performance Solutions LLC, AZ.
Wikipedia lists two second-hand aircraft (ex-Haitian AF) as operated by private companies. However, this webpage list the airframe number, 022/02-012, as being from the Singapore AF, 391 (9V).
SIAI Marchetti S.211 production list
The above webpage also lists a number of Singapore AF aircraft reregistered with N numbers beside the couple from Haiti.
73 Eric
