Navtex Question ?
BOBRR
Boston, MA
Hello,
If I leave the radio on all night with hopes of recording Navtex, what's
the best bet for how to tune:
a. a "bit" below the quoted frequency and use USB mode ? (one or two Hz below ? which ?)
b. the quoted frequency, and am ? (what filter width would be best ?)
c. or ?
Any hints and suggested would be most welcome.
Thanks,
Bob
trentbob
W3BUX- Bucks County, PA
Hello,
c. or ?
Thanks,
Bob
I noticed that nobody's responding Bob but I remember navtext as being a weather information, maybe automated, at 518 megahertz for ships at sea?
I'd have to do some investigating on the internet, do you have Google? I'm not sure what the status of this is because it might have been in the '80s??
I think it's still mandatory for ships over a certain tonnage but my knowledge is limited and I'd rather see you researching. Try putting it in Google in in several different ways.
nd5y
Wichita Falls, TX
NAVTEX is on 518 kHz. That's the center frequency in between the two FSK carriers. The exact frequency you need to tune to depends on what kind of receiver and decoder you are using.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Oh there's LOTS more than that...
Bob it would be most helpful if you would say what SDR or radio you are using and which software. Did you know that there's a reflector devoted just to 518 khz listening? Looks like a very busy place
Of course you could simply try tuning in a signal in the early evening using whatever setup you're using. You won't damage anything by mis tuning something and not decoding properly. Just sayin'....Mike
BOBRR
Boston, MA
Hello All,
Much thanks for the thoughts and comments.
Most appreciated.
To answer some of the questions:
Have an Icom R8600 radio.
Would like to decode to a mac.
Trying with the BlackCat Navtex decoder. (are there any other "mac" Navtex decoders ?)
Another Question:
Do I want to tune the radio to the basic center frequeny, like 518 KHz, and set the
mode in the radio to FSK ? Or, ?
Wide Filter width ? e.g., ?
Thanks again.
Great hobby for my Sr. years, but can be a bit
frustrating at times.
Regards,
Bob
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
There are 2 others that can copy SITOR-B. Note that NAVTEX is built on a SITOR-B engine so if the software copies SITOR-B it will also handle NAVTEX
I don't have a R8600 but if it were me, I'd simply tune 518 khz in USB, wide filter for now, and if it doesn't work, tune down - you may need a 1.7 or 1.8 khz offset to get the right tones. It depends greatly on how the 8600 handles a FSK signal and passes the tones. It will take some experimentation to get this right.
There is a pretty active R8600 reflector on groups.io, viz
Mike
BOBRR
Boston, MA
Hi,
The following list was from a Post by "Saint"quite a few years ago.
If Saint is still monitoring, or anybody else, what are they ?
They are Not Navtex, are they ?
"All these frequencies work for me down hear in Fort Erie Ontario Canada, hope they help you.
KHZ
6312000
8414000
8415500
12578000
16804500
16804000
16806000
Good Luck. Saint"
Saint
Hi,
KHZ
6312000
8414000
8415500
12578000
16804500
16804000
16806000
Good Luck. Saint"
These are GMDSS, DSC frequencies that I pick up Navtex on from time to time. I can confirm I received navtex on them also.
Saint
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Bob I would advise sticking to one problem at a time. Use the reflectors I suggested, as they will be the best place to go for help with NAVTEX. Any reflector that is devoted to a receiver is likely to have some pretty sharp folks there.
If you do decide to go into DSC decoding there is yet another reflector devoted to that topic
And of course, don't forget the Utility DXers Forum reflector, too. Lots of sources for information
Mike
BOBRR
Boston, MA
Hi,
Lots of really very good info. for me to digest today.
Sure is a lot (for me) to learn.
Just want to sy. quick thanks to everyone.
Help and suggestions are truly most appreciated.
Thanks again, Best regards,
Bob
