NC ALE frequencies?
vdubb16
Havelock, NC
north carolina has a division of alcohol law enforcement. "ALE" , they are statewide, so im not sure if there are different frequencies for different areas is anyone familiar with this? if so, does anyone know where i can find their frequencies?
tcainbur
Graham, NC
Ncale
You can find these seperated on teh NC VIPER System
Click Here
http://www.radioreference.com/modules.php?name=TRSDB&sid=4087
NC Alcohol Law Enforcement (ALE) Talkgroups []
DEC HEX Mode Display Description
5776 169 A ALEDIST1 ALE District 1- Point Harbor
5808 16b A ALEDIST2 ALE District 2- New Bern
5840 16d A ALEDIST3 ALE District 3- Wilmington
5872 16f A ALEDIST4 ALE District 4- Raleigh
5904 171 A ALEDIST5 ALE District 5- Fayetteville
5936 173 A ALEDIST6 ALE District 6- Greensboro
5968 175 A ALEDIST7 ALE District 7- Hickory
6000 177 A ALEDIST8 ALE District 8- Charlotte
6032 179 A ALEDIST9 ALE District 9- Asheville
6064 17b A ALEDIST10 ALE District 10- Future
6128 17f A ALECOMMON1 ALE Common 1
6160 181 A ALECOMMON2 ALE Common 2
6192 183 A ALEWIDE1 ALE Wide 1
6224 185 A ALEWIDE2 ALE Wide 2
or on 42.840 I have heard Car to Car Action in Alamance and Guilford Area. Right now there is ony a few officers covering districts. They are expected to hire more with the passing of the NC Lottery.
kg4uad
Pickens, SC
Wnc Ale
In WNC, ALE is on VHF Lo Right in with NCHP. the only "Officialy" listed frequencies for ALE are NCHP F-17 42.7200 MHZ (ABC Enforcement)
NCHP F-11 42.8400 MHZ (ABC)
NCHP F-12 42.8600 MHZ (ABC)
Of the ALE agents ive seen around town i will say they have the low band radios in their cars but i have never heard traffic on these frequencies or low band for that matter. I have seen them with VHF Hi portables with local law enforcement programmed in and have heard them occasionally there. I assume in the Asheville/Hendersonville areas anyway that they use cell phones more than anything else.
tcainbur
Graham, NC
Nc Ale
I talked to ALE in Alamance County area. They say they mostily communicate with Nextel right now. But still use the 42.840 for car to car or Walkie to Walkie. and communicate with Dispatch for Regular highway Patrol Channels. You have to be really close to the signal to pick these low band freqs up on car to car or walkie to walkie..
kg4pbd
On the Charlotte TRS I hear numbered units with an "ABC" prefix. Are these also ALE units? They show up on whatever TG covers the area they are operating in.
jeffmulter
Fort Mill, S.C. (just south of Charlotte, N.C.)
>> In WNC, ALE is on VHF Lo Right in with NCHP. the only "Officialy" listed frequencies for ALE are >> NCHP F-17 42.7200 MHZ (ABC Enforcement)
In Western NC, ALE agents would use the same three channel pairs as NCHP uses in Troop G, which should be channels 1 and 2, 9 and 10, and 17 and 18.
42.84 does not have an NCHP channel designator ... that I know of. It is only available to ALE units. NCHP TX channels 11 and 12 would respectively be 42.86 and 42.82 MHz.
42.84 is generally used for tac purposes, although some of the ABC warehouses also have access to this channel. I've heard the Hickory warehouse on occasion. The agents do not have a "dispatch" to work with on 42.84, so they access the NCHP telecommunicators on the local NCHP channels if they need assistance. On low band, they I-D as Nx (x is the ALE district letter), followed by a two digit unit number.
Keep in mind that ALE agents can work some strange hours, due to the typical hours of operation of business establishments they oversee. Many of us have probably enjoyed a REM session or two by the time the ALE agent ends his / her work day.
Jeff Multer
pboy
County ABC Enforcement
There is a local level of alchohol beverage control known as ABC separate from ALE.
This link might help explain: http://www.ncabc.com/boards/law.aspx
kg4uad
Pickens, SC
ABC Officers are local Law Enforcement
Statewide Local ABC Commission Enforcement is carried out by a local law enforcement officer designated by the commission to inspect ABC governed establishments within that officers jurisdictions. The ABC offical has the right to conduct onsite inspections without a warrant but only that designated offical another sheriffs deputy or city police officer cannot do a warrantless inspection without a warrant. In any event ABC Commission Officals would use local law enforcement comms. as it would be there own.
FireCop
Retired Public Safety Grunt
Statesville, NC
I worked in Meck. Co. several years back. At that time, CMPD had several specially trained officers to enforce ABC laws & regs. I don't know if the city or county has added officers paid by the ABC board. If so, that could explain the ABC units being heard by kg4pbd.
