moonbounce
- Joined
- Nov 5, 2002
- Messages
- 1,423
I am installing SDR Sharp version 1193 and Frequency Manager and Scanner Plugin V1.4 on a new computer running Windows7 Pro.
I have downloaded SDR Sharp version 1193 and installed it from my download file into a folder in my Documents file. I run the program and everything work perfectly..
Now I download FM and SP V1.4 to my downloads file and extract all files into a folder in my Documents folder. Now I open FM & SP and go to the file that says Plugins Setup and right click on that and set it to run as Aministrator. Next I go down to the last file System,Data.SQlite.dll and left click and click on properties and "unblock SQlite" now I am ready to install FM & SP into SDR Sharp 1193.
So now I run the setup for FM and SP. The install goes perfect but when I go to run SDR Sharp I get a box come up that says SQlite did not instal and the program will shutdown. I have gone through this process four times but each time I get the same problem. Any help would be appreciated. I did the same set up on another computer the same way and it worded perfect.
MB
s
MB
s
