Need deg/elev for FLTSATCOM 8
bglatour001
New Liskeard, ON
I live in northern Ontario (47.516667, -79.683333) and was wondering if fltsatcom 8 was visible to me. If it is, what would the heading and elevation be for me? If not, what fltsatcom sat would be?
Thanks in advance.
Dorset, South UK
FSC-8 pointing
Hi,
At its mid-point, you will be able to see Fleetsatcom-8 at 113az / 11el. You should be aware that the satellite is in a highly inclined orbit, at its lowest elevation, it will be 120az / 4el, and at its highest, 106az / 20el. If you use a reasonable antenna, its beamwidth will easily copy with the inclined orbit.
Use the 250.550MHz fleet broadcast bpsk signal as your antenna pointing aid.
regards,
Paul
UHF Satcom (uhf_satcom) on Twitter
bglatour001
New Liskeard, ON
Thank you very much. I can hear them with my 2M/70cm whip but had no idea where to point an antenna once I have one built.
red-dog
italy
Fltsatcom 8
I can not make the tracking of FLTSATCOM 8, I live in Lecce (40.1838 - 18.1206 South Italy) you can give me some help? Are the Keplerian data for this object?
Current Information on FLTSATCOM Constellation
Satellite (Status)
F1/Atlantic (reserve) 1 4.5 deg West Alpha
F7/CONUS (primary) 99.9 deg West Bravo
F8/Atlantic (primary) 22.7 deg West Charlie
I hope this helps.
