Need device manager help installing USB/Serial for programming
jajehalbig
I just bought a USB-1 cable to connect my BCD996XT to the computer for faster programming.
I've installed the driver, and I'm following the setup instructions. However, Windows 7 is supposed to detect the driver "Prolific USB-to-Serial Comm Port" under "Ports (COMM & LPT)" in the Device Manager. The thing is, I don't have the "Ports (COMM & LPT)" option in my device manager. Any help would be much appreciated. Thanks.
(I've gone into "View" and displayed all hidden items. Still no "Ports (COMM & LPT)" option in my device manager.)
jajehalbig
OK. I believe I've managed now to create the Ports (COMM & LPT) option in my Device Manager by going to Run and typing "hdwwiz", then choosing to "Install the hardware that I manually select from a list", clikcing "Show all Devices", and then adding a standard port.
Now I have the Ports (COMM & LPT) option in my Device Manager however both the Port (COM3) and the Universal Serial Bus controller - Unkown Device are still showing me the yellow exclamation triangle.
RonnieUSA
Rowan County,KY (Morehead)
You should install the drivers before plugging in the cable.
Then Windows will do the rest.
jajehalbig
I did. The driver instructions were very clear to install the software before plugging in the device. It's still coming up as an unknown USB device with a status of "Windows has stopped this device because it has reported problems. (Code 43)".
RonnieUSA
jajehalbig
I've tried several times at a total driver uninstall and rebooting, cold-booting and such. I've even tried updating then uninstalling all of the host controllers and USB devices then restarting to get everything back to a default.
Same problem. Unknown Device in Universal Serial Bus Controllers and not showing up in Ports (COMM & LPT).
RonnieUSA
You may have one of the cables with the pirated chips in it.
That is not your fault. Prolific chips set is known for pirating.
jajehalbig
I sure hope not. I think I should try it out in another computer and see what results I get. If the results are positive in another computer then I suppose I'll have to take my computer to a pc repair shop. And if I fail using another computer, then this cable will be returned to the seller.
mikebennett
Sherman, TX
I'm not sure which software you're using but a lot of people are reporting problems with ARC XT PRO using the USB-1 with WINDOWS 7.
You might check out the thread, "ARC-XT PRO LOCK-UP ON READ FROM SCANNER", dated 04-04-11. I ended up using another cable for programming and the USB-1 for logging purposes.
Mike
jajehalbig
Well I just received a USB-1 cable direct from Uniden. I performed the install and everything went great. Buyers beware, even if sellers advertise a USB-1 cable and charge you the same as Uniden, they may be selling you a pirated chip, as it was in my case.
mur
San Jose
If I buy a Serial Rs232 to USB adapter, can I use the cable that came with the scanner, or do I need to purchase a complete cable
Thank you
