TRX-2: Need EZ-Scan Text and Clipboard Import Format Help
SOFA_KING
SE Florida
Send me that .csv you used in the illustration. If it works, then I'll know there is an issue in Excel on this side.
Send it PM if like.
Thanks.
Attached! It had to be zipped (forum rules). Extract it and give that a try. Same file I used in my pictures.
Phil
  • Whistler EZ-SCAN Ham Frequency All Mode Text Import Format Examples.zip
milcom_chaser
Phil
Thanks Phil, this confirms it's an Excel issue on this side. Results of your file directly imported into EZ Scan.
SOFA_KING
SE Florida
Cool! Glad you got it to work.
I believe it was that extra stuff beyond what EZ-Scan could accept, and not Excel. But then again I do not use the latest version of Excel, so I can't say for sure.
Cheers!
Phil
kc8tmv
Cincinnati, Ohio
I can import radio id's ok (about 20,000), but during my import, I can not see a drop down to select the "scanlists" column to map. I am on the "Radio ID Details" tab of the "Trunked Radio Systems" tab of the TRX-1 EZ-Scan software version 3.1. So it defaults all my radio id's to only be associated with scanlist #1. What's up with that? You should be able to map all data elements on an import.
Again, I am trying to import RADIO ID's on the radion ID detail tab, not import frequencies / talkgroups.
AggieCon
Texas
It looks to me like they have not updated the import function for trunked radio systems.
