Working on learning CPS2 with 6550 now, will be adding 7550e when it arrives. I have questions about UHF DMR programming and looking for a wizard to answer questions.
Thanks in advance
Thanks in advance
Thanks in advance
^^^Ask away.
There is no FPP as you imagine it. Unlocking the front panel doesn't do much except allow user to change some names and work with some button assignments. FPP in the USA is limited to Fed Gov users generally.
I can't imagine anything more frustrating than trying to program one of these from the front panel.
Next step is to add repeaters.
1. I'm planning zone 2 to have several local repeaters, probably no more than 6 or 7. Additional zones would be for other areas where we travel (when we travel?). Is this logical use of zones?
2. Does the 7550e have the capability to display call signs instead of DMR number? If so, where would they be added and what type of lookup table would the 7550e recognize? I really don't want/need a global list but USA would be fine.
Buttons>Numeric Keypad>Channel in Home ZoneZones?
I have the K8BIG repeater programmed into Zone 2 and named that zone Local.
After uploading the revised code plug I am not able to select the new zone, the 4 channels I programmed for the K8BIG repeater show up on the channel select knob under my MMDVM zone (originally zone 1).
Been through the general settings, contact list and zone programming but not finding anything that would allow me to change zones on the radio front panel.
1: yes. Zone set up is what ever you want it to be.
Very common problem with people that get new 7550's and have no idea why every channel is in the same zone.
I"m thinking of program efficiency and making it easy to find different repeaters in different states. Right now Zone 2 is Cincinnati local but likely will add Dayton and Columbus at a later date, for sure if Xenia happens next year.
Maybe each zone should really be a state, all repeaters in one state in one zone? What say you?
+1 on thisIf i was building a Brandmeister/DMR-MARC codeplug, I would make a zone for each repeater, and all talkgroups available for the repeater starting with international TG's first, then national, state, regional, local. I would also create a bank for DMR simplex, and a bank for analogue simplex.
My VHF XPR5550 has around 34 zones currently and covers 2 provinces(my most traveled areas)
