HT1000 Need help finding a radio part.
CopperWhopper67
Two of my HT1000s are non functioning right now because I need to replace a small crucial part that I can't find online thus far (primarily because I'm not sure what it's called). It's the small bridge/interconnect, I guess you could call it, that connects the RF board to the logic board.
*I attached a picture of one of them for a radio...reference, horrible pun intended*
Any pointers to where I can procure a couple of these, or any pertinent advice, would be greatly appreciated.
Many thanks!
As you can no doubt see, one of the pins on this component is not there. That was my fault and is why I need two.
krokus
Southeastern Michigan
Many thanks!
What is the spacing between the pins, in rows? What is the distance between rows, and between the sets of rows?
Sent using Tapatalk
CopperWhopper67
Sent using Tapatalk
The inner rows are connected to each other and the outer rows are connected to each other.
The measurements are as follows:
All distances were self measured so allow for a +/- 0.3 mm error margin.
The black housing is 8.25 mm x 13 mm
The inner rows are 10 mm apart
The outer rows are 12.5 mm apart
Two rows on either individual side of the unit are 1 mm apart
Each adjacent pin is 1 mm from the nearest pin in the same row.
The pins themselves protrude 4 mm down from the base of the component.
The unit as a whole measures 13 mm x 12.5 mm
jeepsandradios
East of the Mississippi
From an old service manual it looks like -
J704 0905461X03 Connector, 20-pin; to P704 Strip
Connector
Its probably worth just grabbing another couple cheap HT1000's off ebay for parts to get it. I actually have a box of old broken HT1000's specifically for this reason. Its not band specific so any band will work as long as the part is there
