Need help identifing antenna
coastwatcher
Hi, I need your help IDing a antenna, I saw on line last week. I can not find it anywhere. It is a new model,made in Japan. I will describe it as best as I can.
It has a grey circular plastic housing looks to be 12" in dia. w/4 elements in a X patern coming from it. This is a
all band base scanner ant. Any info I would be grateful for.Thanks, Duke
coastwatcher
need help with antenna
Thanks for the replies. This antenna still eludes me. Iam
aware of the referenced omniX,and that is not what I saw. Thanks for your help, Duke
