need help looking for a mod
balou
ontario
ok what im looking for is a disc tap mod for a adi ar-146 2m radio
the reason why is beacause i want to run it on trunk 88 full time
thanks in advance
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Some, but not all, 2 meter radios have a pin on the mic reserved for '9600 baud out'. If you connect to that and the signal ground, you should have all that you need insofar as audio from the radio is concerned.
73 Mike
balou
ontario
JP-1
Pin-out
Pin 1 - Mic Input
Pin 2 - PTT
Pin 3 - N/C
Pin 4 - N/C
Pin 5 - N/C
Pin 6 - Speaker**
Pin 7 - N/C
Pin 8 - GND
thats all i could find on this radio ..not too sure where to go from there
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Hmmm...guess not. What you will need is a service manual that lists out all the parts; from this you might be able to figure out what chip is used in the discriminator. It should be then possible to make a tap from this point to an unused pin on the mic jack. There's already a signal ground there.
Certainly would take some homework. It would almost be worth it to get an old scanner and put a tap in there. There are LOTS of places to find information on that on the web. Sri ! 73 Mike
balou
ontario
PIN 1 MIC.
PIN 2 PTT.
PIN 3 DOWN.
PIN 4 UP.
PIN 5 + 8VOLTS ( max 150 Ma ).
PIN 6 RX AUDIO OUT.
PIN 7 MIC SCREEN.
PIN 8 GROUND
would pin 6 be the one
