Need Help Picking a Scanner...
ES13Raven
Fresno, CA
Hi,
I am a newbie to scanning and I am looking into buying my first scanner. I want to be able to listen to the police activity in my area.
I'm looking to spend under $150 for a handheld scanner.
Which ones in this price range have the best features and is easy to use?
Bucko
Marietta, Ohio
It appears that all public safety is FM high band & UHF so you could go with a Pro 97 which is on sale for $149.99 plus tax, of course that will run you over that price. The 97 is a good deal for that price for what it does. I believe there are Unidens that are under $150 range like the BC95 & BC 92 but don't have the features the Pro 97 has for the money.
JohnSPWD
Sulphur,La.
Do you want a mobile or Hand held?I would go with the BCD996T.if you have to have the hand held then go with the 396.
Mtirv
Falls Church City, VA
Um.. Theres nothing Digital there, and nothing interesting is trunked. Also notice his money requirement.
Go with the pro-84 if you don't need Alpha-Tags. Its only $50 and will do what you need.
If you do need alpha tags, take the pro-97. It will let you listen to anything trunked in your area and has alpha tags.
ES13Raven
Fresno, CA
Thanks for the replies...
Is the antenna that comes with the pro 84 decent, or does it need a better one for more range?
Mtirv
It is not great. If you can afford the upgrade, it would probably be a good idea. With it I get lots of static from frequencies just a county away. Its not necessary, but if you have the money, do it.
ES13Raven
Fresno, CA
Which one do you recommend?
Which scanners under $150 have alpha tags?
Thanks for your help guys.
Grog
Banned
West of Charlotte NC
When the pro97 is on sale, it's $149.99 :wink:
You can get a used pro93 or pro95 on the cheap, between $50-80 or so. They don't have the nice bright backlit keypad, nor ctcss/dcs, but they are still a good 1st scanner.
I used a pro93/2053 (2053 is the base version) for several years, and they are still good scanners.
If you can swing the $150, get the pro97, if you're not sure, get a good 93 or 95.
mfn002
Bryan, Texas
I think he said UNDER $150. Those scanners are $500 and up!
bernnie
RINCON,GA
don't think you are goping to find anything for that price unless you get it from a pawn shop or its HOT thats going to do you a lot of good for that price sorry ~!!
