Need help programming a DMR trunked system on a 436HP & 996P2
rja1
Enfield, NH
rja1
Enfield, NH
I see LCN's & Color Codes.......What are LSN's? This is my first time trying to program a DMR system.
hiegtx
Dallas, TX
The scanners will not make any use of the LSN values. Only the LCN figures and color codes for the site (or sites, if programming more than one) are needed. The LSN, Logical Slot Number, is used in the database here, and is part of the information gathered when using one of the SDR dongles and software for the SDRs such as DSD Plus. See this thread for someone dealing with a similar issue.
Also see this Wiki page:
Make sure that you have the correct LCN entered, and are using the correct color code for each site. You might also try running the LCN Finder (under the Analyze menu link) on your 436HP. The 996P2 does not have that feature.
