Need help with Encryption ADP
FDRadioguy777
My dept would like me to try out ADP encryption on the admin channel. I have an XTL 5000 and it had an AES 256 encryption board in it so when I was in the CPS and I tried to change from hardware to ADP the reading glasses came up. I removed the encryption board from the radio, read the radio, and I am still having this issue. Can anyone help me with this? The radio has ADP in the flashcode.
snoopyII
On the other side of the tracks
I would go through the personalities and see if you have AES strapped to one of them. If so break those associations and re associate them with the ADP.
snoopyII
I've tried a variety of things and can't seem to replicate your problem, where you are not able to select between hardware and software. Although I'll admit the above is a longshot, because encryption associations in my test CP have no effect on the selection between hardware and software. Its possible you have a corrupted CP as well.
rescueman433
Your flashcode may not have software ADP in it. If it doesn’t you either need to find a way to flash ADP in it or get a hardware board off the bay with the algorithms you desire. The software ADP selection in CPS is standard wether you have the flash option or not.
