Need Help with ICOM F11 Programming
kylech99
Illinois
I recently purchased the ICOM F11 programming software.I programmed the radio but now the green lgiht stays on all the time and the squelch is on. I put the PL Tones in for the TX. How do i get the green light shut off and how do i get the squelch noise down? Please help me!
edjanowetch
Grants Pass, OR
Icom F-11
Put the same pl tone for rx. the squelch will close except when recieving.
Set the squelch for about 70 in the common settings ,common 1 the green light will go out except when recieving.
Enjoy.
