This is pre-programmed
GRE PSR-700 Police Scanner
GRE PSR-700 Scanner
Our Price: $189.95
Hear all of the action in your area without the complicated programming of frequencies. The GRE PSR-700 has a built-in SD™ card pre-programmed with a database of all known analog (non-digital) public-service trunked systems as well as many conventional frequencies. Just select where you are and what you want to scan from pre-installed lists. It's as easy to use as an MP3 player. Hit play (not SCAN) and you are scanning the local action. It just couldn't be any easier.
Product Code: 30-501529
This one is not pre-programmed..Can be programmed with Computer with appropriate software
GRE PSR-310 Police Scanner
GRE PSR-310 Scanner
Our Price: $199.95
• New Object Oriented User Interface
• Wide Band Reception
• Multi-System Analog Trunking
• Full dot matrix bitmap LCD Display
• High Speed PC Interface
Product Code: 30-501543
Both of these can be ordered from scanner master....any dealer is about the same price. Now the rub is if NN ever goes digital, you're screwed. By the way I was a medic for the city for 10 years before I went back to college. Was at #2 and #9 stations. Was there from 1988-1998
