I have an NX-700 that was working just fine. It is mounted in the vehicle. However today it will not turn on. I checked the power cables, fuses, and it is getting power, in fact when I disconnect the power I can hear the speaker click so there is power to the unit. It is not set up for ignition sense and has been working fine turning on and off as it should until today. I did look at the last programming and ignition sense is not checked just to cover all of my bases. It is set up as a remote mount, and all connections are on and tight and again has been working. I brought it inside and connected to an inside 12v power source but still will not come on. Is there a fuse inside of the unit I might need to look at or any suggestions would be greatly appreciated. I am hoping it is something simple. Thanks for any help and direction.
