Need help with programming Kenwood radio!!!
DS2194
Hello! Let me start by saying that I have a general knowledge of radios/scanners and how to program them and I am generally okay when it comes to dealing with computer software. I recently came into possession of an older Kenwood UHF FM Transceiver. It is a Kenwood TK-372G. My department got all new radios so now I have this one for personal use. This radio is already programmed with set channels from when it was used on-duty. I would like to erase its prior programming and completely reprogram it with my own channels for personal use. What is the best way to program this radio without spending a lot of money on expensive Kenwood programming software?
I have tried using CHIRP to program this radio. According to CHIRP, this radio is compatible to be programmed with the software. I am using a two-pronged Baofeng brand programming cable. When I attempt to communicate with the radio and clone the current channels to reprogram, it seems as if it will work until the last moment when it states that there was an error.
All in all, what is the best way to program this Kenwood TK-372G without dishing out a lot of money on expensive software or paying a technician to do it? Any help would be greatly appreciated!
car5le
Northwestern Montana
There isn't...
You either have to have the software specific to that radio, or go to a tech who has the software. The cable you have will probably work. Baofang, Wouxun use the same pinout on their cables for programming as Kenwood does.
And no, CHIRP won't work as you found out... :)
Set up your Private Messaging and I'll explain more.
In the world of commercial radio, Kenwood programming isn't expensive, especially when compared to others.
Since this is an older radio, there will be a good selection of after market or used, so obtaining an appropriate cable shouldn't be an expensive proposition.
Kenwood doesn't have the programming software for the TK-372G listed on the "dealer tools" page, and the radio has long since been "end of life'd", so finding software out on the internet probably wouldn't be an impossible task if one was to look.
The benefit of using the correct software and programming cable is that the likelihood of others being able to provide assistance will be greater.
DS2194
Thanks for the help! I appreciate it. I was hoping there was another way to do it, but I will just take the plunge and buy the specific software. Thanks again!
dapaq2
Northwest Indiana
DS2194 it is a good idea to enable your email and/or private messages system so radio reference members may contact you. You just might receive some additional help behind the scenes... :)
toastycookies
the far east
He cannot with only 2 posts. It is not his fault, the system does not allow it.
njffemt08
Was emtfirebug14
Hey yall I've got a similar question. Looking to reprogram my 270. Question is can I do it on a new computer or do I need an older with dos
microx
Northeast Ohio
If I'm not mistaken (and I could be wrong) isn't KPG-56DK the right software for the TK-x70 & x72 series? If so, v4.22 was windows based and ran ok on a Windows7 machine for me. But alas, I don't have access to that computer anymore.
Muhlenberg County, KY
It depends on if they have the G or the non-G version radio. The G version would use KPG-56D, which is Windows based. The non-G versions use KPG-27D, which is DOS based.
Sent from my RealPad MA7BX2 using Tapatalk
olderookie
warrenton mo
I have used chirp on a 270 non G I was very surprised to see it work. channel wideband radio Chinese cable worked like a champ
DJ11DLN
Mudhole, IN
That's good to know...I have a few each of 260s and 270s floating around here, mainly used as TX-inhibited fringe-areas pagers (since they're not NFM-capable), and while I don't mind using 27D, keeping a DOS machine viable these days can be a little challenging.
