Need Help With Programming Radio!
indians9286
Hello,
I really need some help programming my Vertex VX-354(VHF) radio. I just bought the software and serial port plug from the antenna farm (version 1.10). I am using windows xp. For some reason when I plug my radio in, my computer says there is a communication error. I went through every possible setting under the configurations menu and I still have no luck. I would appreciate any help! Would this be a bad plug? Also, If I updated to windows vista would this help?
puzzleriddle
bham, Bama
hmm, I have no ideas, but ya get the latest drivers for the programming cable?? and install em:). then select comport the cable is on with the software, make sure both are the same.
