Need help with TrunkView Please Vic SMR
slylingus
Victoria Australia
Gday I have searched the forums for trunkview help and none match my specific question. So here goes.
I have successfully set up trunkview and every thing is working fine scanner leaves control ch and goes to voice ch but i get no voice.
Also I cannot edit my sites databases under the edit function, I have tried 3 other PC's and it is the same is this a simple problem does the software need to be registered?
When I go to edit site database uner options trunkview just beeps as if the option does not exist.
TrunkView V2.21 BCD996XT does not work at all is it supported yet?
I am using a UBCD396T My control Chanel is 165.07500 (VIC SMR) My Base Ch is 165.05000
00:31:44 ******* TrunkView :: MPT1327 Protocol Decoder ------ Saturday 2009-12-26 ********
ID: 5981 | One Tree Hill | Cch Frequency: 165.07500 MHz
00:32:39 - GTC | Go To Channel - Voice | (041) Org: 6112 Tar: 6305
| Ch: 315 Freq: 168.98750 MHz |
So I am assuming my base is right as someone else worked it out?
Any help would be appreciated as i am new to dynamic scanners i have been setting up TV for some weeks now and am at a loss Cheers From Aus
Comint
Queensland, Australia
TrunkView does not require registration.
V2.21 was released long before the XT, so possibly not.
NEVER assume anything. In your above example, Ch 315 is actually 165.3750 MHz.
The VIC SMR requires a Custom bandplan, with Ch 1 as 162.0625 through to Ch 251 as 165.1875 - then - Ch 301 as 165.2000 through to Ch 364 as 165.9875 MHz.
TrunkView will only allow about 29 Custom channels in a Profile, so what you have to do, is create a Profile in TrunkView - add a few Channels - save the Profile, then exit TrunkView and edit the file, with something like Notepad or Wordpad, to enter the rest of the required Channels.
Comint
slylingus
Victoria Australia
Thanks comint
I have been using notepad to edit and i think my band plan is set up correctly.
[Custom channels]
001=162.0625
002=162.0750
363=165.9750
364=165.9875
My Base freq is my issue I think from your last post I came up with the following
165.3750-(315*0.0125)= 164.4375 as base feq
When I use 164.4375 as my base freq I get the right voice channel BUT my custom band plan changes and returns me to 164.4625 as base freq. So I'm at a loss my band plan just changes?
23:46:16 ******* TrunkView :: MPT1327 Protocol Decoder ------ Saturday 2009-12-26 ********
23:51:41 - GTC | Go To Channel - Voice | (041) Org: 5633 Tar: 6305
| Ch: 315 Freq: 165.37500 MHz |
23:51:58 - CLEAR| Call clear-down | Ch: 315 Freq: 165.37500 MHz
| Return to Control Ch: 242 |
Any way thanks again any more advice cheers
Comint
If you have to use a Custom Band Plan, then you don't use a Base Frequency. Leave it Blank.
The reason you have to use a Custom Band Plan is because the Channels do not conform to the standard 'Base frequency' format.
Comint
slylingus
Victoria Australia
Thanks when left blank this is what happens on loading profile says site details of 5981 missing and it creates it own band plan
06:57:50 - GTC | Go To Channel - Voice | (041) Org: 5750 Tar: 6305
| Ch: 315 Freq: 3.93750 MHz |
Don't I need a base freq for it to refer to the band plan
07:02:39 - CLEAR| Call clear-down | Ch: 315 Freq: 165.37500 MHz
<?xml version="1.0" encoding="iso-8859-1" ?>
<?xml-stylesheet type="text/xsl" href="sites.xsl" ?>
<catalog>
<head title="- TrunkView Site information -" />
<site show="1">
<name>One Tree Hill</name>
<sysid>0x5981</sysid>
<cchfreq>165.07500</cchfreq>
<basefreq></basefreq>
<step>12.5</step>
</site>
</catalog>
Comint
Just saved as SMR
The Profile filename has to contain at least part of the Site Name, otherwise TrunkView has no way of finding it.
In the case of 0x5981, it would have to be named at least
One Tree Hill.tvp
One Tree.tvp, or
One.tvp
However, what I would suggest, is that you rename 0x5981 to 'SMR One Tree Hill', and keep the filename of SMR.tvp, for the Profile . This will allow the one Profile to be used for all SMR Sites. The Site Name of every other SMR Site must also have ''SMR ' as the first characters, for this to work.
Comint
slylingus
Victoria Australia
That did the trick now it matches my profile names etc Thanks
13:00:04 - GTC | Go To Channel - Voice | (DSE/PARKS VIC) Org: 1625 Tar: 2397
| Ch: 207 Freq: 164.63750 MHz |
13:00:31 - CLEAR| Call clear-down | Ch: 207 Freq: 164.02500 MHz
<site show="1">
<name>SMR One Tree Hill</name>
<sysid>5981</sysid>
<basefreq>
Still not sure what to put here to return scanner to correct control CH
</basefreq>
<step>12.5</step>
</site>
161.4375 get me the right voice freq but returns me to 164.4625 as control my calculations are wrong somewhere Cheers
Comint
[Custom channels]
001=162.0625
002=162.0750
363=165.9750
364=165.9875
[Custom channels]
<--- You don't actually have a Blank Line here, do you?
001=162.0625
002=162.0750
The Base Frequency field has NO relevance when using Custom Band Plans. With the SMR you would need two Base Frequencies - one for Chs 1 to 251, and one for Chs 301 to 364. Thats why a Custom Band Plan has to be used.
Comint
slylingus
Victoria Australia
No blank line (file attached)
I am using the alternate control channel as there is no signal on the primary
006 6 Bendigo 164.20000 164.42500 164.63750 164.72500 164.86250c 165.07500a 165.37500 165.67500
slylingus
Victoria Australia
Bingo I put 162.0500 in base freq and it returned to control Chanel on scanner.
It set its self up as ch 00 on the band plan
Thanks for your help comint this forum for new users is much less intimidating when you are feeling your way around
<basefreq>162.05000</basefreq>
<step>12.5</step>
</site>
Comint
Too bad no one has submitted the correct SysIDs for the SMR Sites on the Radioreference Database, or the Latitude and Longitude (in WGS84 datum) for each Site, then you could end up with a display like this.
That entry should read:-
22913 5981 Bendigo etc.,
TrunkView shouldn't even be looking at the Base Frequency field, when using a Custom Band Plan, but you can try 0.0 MHz or 162.0500 MHz.
Comint
slylingus
Victoria Australia
Thanks I am not too sure about TV my copy does not allow me to select edit site data bases under the options tab.
You look like you have been busy with Vertel UHF MPT1327 - Site Map
For bendigo what does 22913 stand for
slylingus
Victoria Australia
Don't know what would be causing that.
22913 is just the Decimal equivalent of the Hexadecimal 5981.
Comint
I does it on three PC's screen just flicks,I've downloaded it several times that has been most of my stress with setting up! Ive tried anti virus on off etc all the normal things just one place to download it from as well
All in the past now Vic SMR is rolling in it's a whole new world of scanning.
tonsoffun
Senior Moderator
Moderator
Central Ontario
Do you guys want me to move this to the Australia forum? We got a reported post to move it there. We usually don't move threads out of this forum without the users permission:)
Comint
Might as well. It is really related to an Australian specific problem, namely the Victorian SMR.
Comint
Comint
Does Ctrl-D work?
Do you have both a sites.xml file, and a sites.xsl file, in the TrunkView folder?
The xsl file is responsible for formatting of the data on the screen.
What operating system are you using?
Comint
