Need Little Help
budevans
Cleveland, Ohio
Ok I have almost gotten this down how to program this scanner BCD396xt I think butttttt I went to put in Staley's Communications and I see its DMR Motorola Connect Plus (TRBO) so im asking would it be Motorola Type II SmartZone conventional or ?
TRBO is a Motorola proprietary digital system. No scanners currently support it.
But, if you go to the Digital Voice Decoding Software forum they may have software that you can install on a PC in conjunction with your scanner to decode it. Here's a link:
Digital Voice Decoding Software - The RadioReference.com Forums
mikewazowski
Staff member
Central Ontario
Connect Plus and Capacity Plus trunking is Motorola proprietary but plain old TRBO is just DMR which is not proprietary.
Because of that, you can use any vendors DMR capable radio to listen.
KCChiefs9690
CQ DX
Lewis Center, OH
mikewazowski
Staff member
Central Ontario
No, as previously reported, no scanner will be able to monitor the system.
You either need to use DSD or buy a commercial DMR radio.
coolbammer29
(Maynard) St.Clairsville Area Belomont County
Ok then I mise well take them out of my scanner then....
I also notice after i uploaded my file in my scanner n when its scanning i see onthe screen some there are numbers popping up on the SO and on GRP on some they are like - - - - does that mean they are missing the group freq? hope that make since
