Need Low profile Mobile antenna
Chevyman22360
FLRAILMAN
Banned
Orange City, Fl.
Chevyman22360
Since your limiting the mounting option to just your roof & the antenna has to be less then 13' tall, "no pun intented" but that's a very tall order. Here goes. Note the extremely limited bandwidth that these antennas are set for. Good luck.
Comtelco Low Profile Mobile Antenna Information Page
www.larsen-antennas.com/docfiles/ASB10/SalesSheets/LOWPRO.pdf
FLRAILMAN
How well do these type of antennas work? Has anyone had good luck with them? It will only be a recieve only antenna.
Thanks!!
code3cowboy
if it is only a Rx antenna, go with a Phantom. They are short and stout, and will perform quite well when surrounded by metal (good ground plane).
Magnetsteve
Central Arkansas
I agree with code3cowboy, the phantom antenna should do the job perfectly for RX only. However, it almost looks like a funky GPS antenna, and is about the size of a coke can, and you can get them in black or white, depending on your preference.
