NEED MILair Freqs....
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Hmm, neither the 96 nor the 95 do all that well in the milair ranges - maybe using the 2032?
You'll most certainly need a good antenna mounted up nice and high.
Anyway, the first place I'd check would be the 'Where to Start' topic of...
http://wiki.radioreference.com/index.php/Milcom_Web_Pages_and_Mailing_Lists
I would then look at Larry Van Horn's 4 state freq list on...
http://www.monitoringtimes.com/html/Quad.pdf
in fact, the Milcom list on qth.net might be your best bet, since Larry is the listmaster. I don't doubt he could point you in the right direction 73s Mike
