longreacher
HI there..I've been steadily making progress, but I've hit a bump. My feed has no output, even though the mic input is turned on and I can hear the scanner in my server's internal speaker when I turn it on. My problem (I think) is with my "device = " setting. The only variable I can put in there that will allow the program to run is "default". However, when I run it with "device = default" I'm getting no output.
I see other people using "device = /dev/sda" or device = /dev/dsp (trying various incarnations of this always gives me this error:
"DarkIce: OssDspSource.cpp:202: can't set format [16]"
I also see people using
device = hw:0,0
Which gives me
ALSA lib pcm.c:2212
snd_pcm_open_noupdate) Unknown PCM device = hw:0,0
DarkIce: DarkIce.cpp:1187: can't open connector [0]
At my wits end here. Thanks for any help you can give me.
device = hw:0,0
Which gives me
ALSA lib pcm.c:2212
