Need VHF antenna for Minitor II amplified charger
ka9rxk
Schaumburg, IL
Hello,
I just picked up a Minitor II VHF pager along with the desktop amplified charger. I am in need of the VHF antenna for it. The Motorola part number is: NAD6310A. A quick "google" search does not return any results for this part number.
Thanks for any help!
-Don KA9RXK
SteveC0625
Northville, NY (Fulton County)
That antenna is just an RCA plug with a piece of rigid, springy wire for a spike. If you can't find one, a quick trip to Radio Shack for the RCA plug, plus a piece of #14 or larger solid copper wire will make a fine antenna. (I'd raid my shed for a chunk of house wiring for the copper.) 5 seconds with a 100 watt soldering iron and you'd have what you need.
ka9rxk
Schaumburg, IL
I know that there are different options here, but I'd rather go with the original antenna for the "coolness" factor. I already have an RCA-to-BNC adapter for this. I never thought that it would be so hard to locate the original antenna. I am sure that there is someone out there somewhere with a box of these collecting dust!
n3obl
PA
they are NLA per motorola.. No Longer Availble
NCFire11
Not sure if the Minitor III/IV antennas are the same, but I have some Minitor IV's id be happy to send you.
But i believe the Minitor III/IV VHF is shorter.
n3obl
PA
NO.. The III/IV uses a bnc on thr amp charger.
Frank
