Need
Sjinndoawi
South Florida
I am looking for a wideband multicoupler(25mhz-1.3ghz) to feed my 3 recievers from one outside antenna. Where can I find one and about how much?
Any help would be great
Brian
thewenk
Idaho DB Admin
Eastern Idaho
Needing a range from 25 MHz to 1.3 GHz may limit your choice somewhat. Most that I've seen have an upper limit of about 1 GHz. Also, many don't go as low as 25 MHz.
Dave
awall
Springfield, Missouri
Go to Radio Shack and get a 3 port cable tv spliter that will work to 1.5ghz. Thats what I use and I just made me a J pole antenna and it works great. Make sure you get the kind that has the cover soldered on so it is sealed. Don't get the kind that has the cover mounted by screws. Those kind allows to much interference.
