new 700mhz system on txwarn
wa1emt
Houston, Tx
ok all. i figure this is the best place to ask.
have a pro-2096.
heard it can and cant do the 700 mhz system on the txwarn p25 system. i also heard that you have to set the rebanding tables. not sure how to do this or if it even works.
i have put 5 towers in the txwarn p25 bank and seperated each cc with 1300mhz so it will trunk track..most say that this works.
however, what do i need to do for it to do the same thing for the new p25 system. the sites near me have the 700mhz freq's and im almost betting that the pro-2096 will do it.
any ideas.
redhelmet13
4 nm se KNFW
The 2096 will not work with a 700Mhz system, you can listen in conventional mode. The firmware was never designed to receive 700Mhz. There was a frequency "unlock" mod that is accessable via the computer programming software which allows receiving the 700 Mhz freqs but only in conventional.
You will need a newer GRE/RS or one of the Unidens that have the 700Mhz range available.
