new aor 7030+
bluefox2163
hi does anyone know if this reciever is a good one I just got one I connected a small piece of wire to the twin lead on back the am band comes in pretty lousy severe buzzing from 600khz thru 1700khz do you thik its the reciever?,the antenna im using,or the reciever anyone out there have one ,can you give me some user reports thankyou?!
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
You're kidding, right? A short piece of twin lead as an antenna? You're probably getting wiped out by so many local noise sources that it's hard to think of them all - anything from your cable router (many are VERY dirty, RF wise), unshielded PC stuff, flourescent lights...Lots of possibilities.
For reviews, and many other things 7030 related, check our wiki...(anything in blue or underlined is a link)
http://wiki.radioreference.com/index.php/AR7030
You get a good rx (although it wouldn't be my first choice for a first HF radio - it's much like the 396 - it takes time to learn all those menus...), you should take the time to put a good antenna on it. The first link has LOTS of HF antenna ideas - the 2nd is mostly for AM BCB Dxing, although some work on the HF band as well. You spent a ton of money on the radio - don't skimp on the antenna....
http://wiki.radioreference.com/index.php/HF_Antennas
http://wiki.radioreference.com/index.php/Loops
73 Mike
Shortwavewave
AOR 7030 is supposed to be a great RX, but its a little on the expensive side for SW Radio, I would definatly get one just because it has 0(yes 0-30mhz) maybe If I got it I could hear some wistelers.
kf7yn
West Jordan, UT
The AOR 7030 is one of the better receivers made but not all that user friendly until you learn the menus. Personally, I prefer a radio with most of the functions available on the front panel rather than menu.
Locate your antenna as far from electrical noise as possible. Remember, radio signals are electro-magnetic and all the things in your house, computers, monitors, TVs, light dimmers, electric motors, etc. are all sources of electro-magnetic interference (EMI). Use shielded coax out to the antenna. Don't use those new power-saving curly fluourescent light bulbs, they are horrible sources of EMI.
bluefox2163
ok thanks for the input so far I have some antennas coming hopefully these will improve the reception on am band ,like you say the little wire antenna is not doing much good except for international stuff!this is a nice radio ,I just dont want to hear that buzzing on am band it drive me crazy...
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
As Jon has suggested, it's time for you to find out what the buzzing is all about. Do a little detective work; put the radio on and start turning things in the immediate vicinity off. Something is bound to be the cause of the problem (it could be more than one thing).
Indoor loops - which are very popular for AM BCB Dxing - are much less sensitive to local noise problems due to their design, but it's not a complete answer. You will still have some issues, I'm sure.
73 Mike
bluefox2163
also note that I dont have a wire connected to the ground lead on the twin lead antenna do you think that could be the reason?
Shortwavewave
One thing you might want to look at is getting rid of CFLs if you have any plugged in(or turned on)
I couldnt find out what was wrong in my house for the longest time, well I finnly found out what it was and I couldnt of ran any faster to lightbulbs and then to the trash fast enoughf
nexus
Mississippi
Bluefox get your antenna OUTSIDE of the house. According to the specs that should be a pretty good receiver especially with collins mechanical filters.
Don't use a piece of twin lead. What you want to do is order you some 450 ohm ladder line wire, This will be your feed line. On one end of the ladder line attach it to the wire ports on your receiver, and the other end you'll want to use something as an insulator, you could buy one commercial, or just use something like a plastic coat hanger (cut to about 3 inches with a hole drilled in each end) or a piece of wood about 3 inches long with a hole cut in each end. Then about 50 feet of Speaker hookup wire. Take the speaker hookup wire and separate it into two pieces 50 feet long, on one end of the wires remove some of the coating to expose the copper wire. Take the other end of your ladder line ( that isn't attached to the back of the radio) and do the same, remove some of the coating to expose the bare wire. Now you're going to take your insulator and attach one of the 50 foot wires to one end of the ladder line through the hole of the insulator, and do the same for the other 50 foot piece and ladder line.
You'll want to find something to hoist that insulator up as high as you can get it off the ground, use a tree or mast etc. and then find a tree or mast or structure (fence side of house etc) to support the two 50 foot wires. Pictures of what I'm talking about below.
Ladder line:
Construction, ladder line meets the 50 foot wires with an insulator.
another view of the antenna extending over the house into the yard.
Picture of a commercially made antenna like the one I described:
