Quickbird144
- Joined
- Feb 6, 2018
- Messages
- 5
Hello everybody. Fairly new to the CB scene. Picked up a used Cobra 29LX from a pawn shop. Found a 4' antenna at my shop and fabricated an antenna mount for my jeep XJ. CB power and ground are ran straight to the battery, using a 18' coax cable with a firestik stud.
The best tune I could get was 2:2 with the built in swr meter. I'm not able to transmit but can hear others talking although not that great.
I found a diagram about checking the connections for continuity and found with my coax cable connected to the radio I'm shorting between the outer connector of the coax and the antenna. Unplugging the coax from the radio, I get an open.
My ground plane is well grounded. Am I missing something or is the CB radio grounding the coax hot side internally? Any help would greatly be appreciated.
