New CDOT TG 2310???
natedawg1604
Denver-Metro
This morning I've been hearing DTRS TG 2310 quite a bit (which is currently programmed in my scanner as a "CDOT unknown"). It definitely sounds like CDOT trucks, so far I've heard locations of I-25, Wadsworth and 6th Avenue. I've also heard a couple "5 John xx" call signs.
So far Pro96Com shows UID's 114313, 136558, 136562, and 136565 associated with TG 2310.
-Nate
rfburns
5J should be the SW part of Section 5 including Patrols 17 and 30. Patrol 17 is S Wadsworth and C470 from 6th to Hwy 121. 30 is east of there. Somewhere around 0530 I heard a supv say he was going to call 5J30 in on snow shift. I had ten hits on 2310 on Lookout today.
