thewraith2008
- Joined
- Nov 22, 2016
- Messages
- 1,847
Tried that and still having the same TCP errors and not working.
When you installed Stunnel did you correctly define "Common Name (FQDN)" when asked?
Not sure if this needs to be your real IP or DNS to your machine.
Code:
eg. DNS = www.example.com
Important Note: The Common Name (FQDN) should be the hostname of the machine running stunnel. If you can access the machine by more than one hostname some SSL clients will warn you that the certificate is being used on the wrong host, so it is best to have this match the hostname users will be accessing.
EDIT: Fixed post formatting.
