New DSD Windows Build 1.6
Open the DSD folder in Windows Explorer.
Right click and select New Text Document.
Double click the new file to edit in Notepad.
Type the following in Notepad:
Select File, Save, and Exit.
Go back to the Explorer window and rename above file to "sh.cmd"
Double click the renamed file. You now have a command window where you can type DSD followed by whatever options you like.
moonbounce
I just found this update and I have a question or two. Do I have to delete dsd 1.4 first before I run dsd 1.6?
Do you still access dsd 1.6 from the command prompt?
I did download dsd 1.6 and ran it, but I can't seem to do anything from the command prompt. Now that I have dsd 1.6, I can't go into dsd 1.4 from the command prompt because it comes up as dsd 1.6. do I have to delete dsd 1.6 in order to work with dsd 1.4 at the command prompt?
Moonbounce
tyytor
Wyoming
hi i am trying to get this thing to working on trbo only, or - FF command
can some one please :) walk me through on the foum or by PM?
to type in the right commands to get up and running?
i an a real nub when it comes to this but willing to learn and listen,
have gone though the fourms and still confused how this thing works.
thank you in advance
aquaroyal
Dowload link down
Can someone supply an alternate download link, or even better, the source code for DSD 1.6? Minus seems to not work. Thanks.
n9mxq
Belvidere IL
don't click the ZIP graphic, click the DOWNLOAD link below it.. Worked fine for me.
foxtail
Niagara Region Canada
Link does not work as above info. Click download goes "page not found"
Anybody able to provide a link or maybe email it. Thanks for your time.
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Tried to download it, but have failed.
Does anybody know the correct address for the download?
Just a couple of posts above I posted a link to the RR Wiki for DSD. On that page there are many links for download. I guarantee one of them works.
Mike
nbarco
Grovetown, GA
Couple of questions...
Will this work on Windows 8?
Once I install the .exe file, do I need anything else?
vans113
Tennessee
in my link above i have uploaded the cygwin file and dsd in my drop box. I believe i have some older versions of dsd if anybody wants those also.
mtindor
OH/WV DB Admin
The link does not work. I even tried signing up for Minus to get to download the file, there is no green light here. Just a red light.
Sometimes the minus links work, and sometimes they do not. Are you scared of that backup site for some reason? :) It wouldn't be listed in the Wiki if it weren't felt to be safe. Of course there is no cygwin1.dll on the backup site. You'd have to fetch that from Cygwin.
Mike
moonbounce
Here is a link to Wiki where I got my download: Index of /dsd
Now if I could just find a link to text instructions for dsd 1.6:).
Moonbounce
yo3ggx
Romania, Europe
change default audio in or out
Hi,
I want to try dsd 1.6 with the WebSDRsoftware as receiverr, which use default audio output too.
There is any way to change the default audio in or out in DSD?
Thank you,
Dan
