New FCC map info
LEH
Yorktown, Virginia
#1
Not sure where to post this.
I found a couple of errors in the new feature where the map shows trunked system information.
For the Virginia STARS system, two towers in the list are not shown on the map. Hampton and Chesapeake are missing.
loumaag
Silent Key - Aug 2014
Katy, TX
#2
The function works when the license information is available. For example, the Chesapeake site doesn't have a license listed, this is probably because the majority of frequencies listed are unlicensed for Chesapeake and the three that are, belong to the Forestry Department.
